I am installing and INSET wood burner,
i have installed a flexible Stainless Steel flue liner
but i can not figure out how to connect this to the stove
the flue connection does not seem to be covered by the instructions
basically there is a 150 mm hole in the top of the stove
there are 2 bits of 150mm pipe.
one has got 3 holes around it and i assume is for solid pipe
the other one has a slight ride running around it and then 2 bits of sprung metal stick out of one end, almost like clips to hold something in place
both of these fit into the top of the stove with ease. but there does not seem to be anyway of securing them,
being and inset stove you have to get the at flue connection from inside the stove
can any one advise ?
