Wood Burner Inset into existing Fireplace
31 Mar 2006
London
There will be a 30mm gap at the back between the existing firebricks and the stove, I am worried that any falling soot may eventually ignite. I am advised I do not need a liner as the chimney has been tested and no leaks. It has been suggested that I pack this gap with loft insulation, is this O.K.? Also on top of the stove (inside the chimey, around the flue opening.
What sort of stove are you talking about? There are stoves that are designed to be built into a fireplace. Stoves not designed to be built-in are not designed to be built-in. You should have the ventilation and clearances stated by the manufacturer.
The stove is an Insert Stove, designed to fit into a standard 16 inch width fireplace. It is just that my firepace is a bit deeper than the stove, anyhow I have decided not to pack the space with loft insulation, as suggested by the supplier, but rather fill the gap with firebrick. Thanks
You wold be better to listen to the manufacturer, and if they don't give the advice in the installation instructions, ring them up and ask. I am assuming the supplier is not the manufacturer.
Oilman, yep did just that, and they gave me the right advice, which is to fill the gap with a mixture of Vermiculite 5 to 1 with Portland Cement. Should jave guessed that was the right thing to do, once the supplier was not too sure. Thanks
