I am building a workshop in my garden here. I have just started to build the timber frame and was originally going to cover the outside of the frame with 11mm OSB then breathable membrame, battens and some form of cladding.
I am now having second thoughts, which is making positioning my common studs a knightmare!!!
I need to keep the costs down and this is the reason for now not being sure. Whilst going ahead with my plan I then thought about the inside of the workshop. If I cover that with OSB as well that will double the cost of the OSB. So I need some options of what methods to cover the timber frame both externally and internally.
I have seen a few methods on where the breathable membrame is secured onto the timber frame then battens are fix and the cladding without OSB on the outside of the frame. On the inside the guy then insulated between the studs put on a vapour barrier and then OSB on the inside.
If I OSB on the outside it would look ok from the inside as you would just see wood but it would not be insulated and if you insulate then it needs to be covered.
The workshop will be used for woodworking, metalworking, welding etc.
