I have a small area of floor to lay mosaic parquet on. The floor has Aquapanel on it as it is was originally intended to be tiled, though it's not a wet area. I have Laybond Wood adhesive to stick the parquet with. The Laybond says that porous surfaces should be primed with Screedmaster Universal primer. I'm wondering if the Aquapanel is a 'porous surface' so do I need to prime it? And if it is, could I use an alternate primer? I don't have easy access to Laybond primer and I'd rather not pay for it if I can use something else that would be suitable for this surface.
Paul
Paul
