Woodstain
10 Jan 2012
Surrey
Hello.
Just bought some Johnstones Satin Woodstain in 'Walnut' for our French Doors. My dad (our builder) says that it's not suitable as it basically contains a varnish and you won't be able to see the grain under the colour.
Is he right?
it will look better if you use a wood dye such as Colron, which will bring out the grain and give it colour, followed by a clear satin varnish.
Thanks John, just looked up Colron and their site says:
Can wood dye be used outside? No, the pigments in the wood dyes will fade very quickly outside.
What do you reckon?
well I didn't know that
I use it on my hardwood door-sills and hadn't noticed it fading, but perhaps it does. I oil mine, and will be retreating this year including rubbing down and re-dyeing.
The hardwood doors have retained their colour, except where the protective coat had weathered off.
Woodstain is not usually a varnish, you can however get coloured varnish, hardwoods used for external joinery often have very little grain to show through which is why woodstain is used, it gives a unifom finish.If you have souht facing doors I would suggest an extra coat or two and at least an extra two coats on any horizontal surfaces [rain combined with wind and sun wear these areas quicker].
