Worcester 24i DHW problem
Hi group, quick update. Looked at boiler last night, removed cover & loosened lower panel containing the PCB & controls, fault persisted, I then noticed that if I went to close the hinged panel, the boiler would fire up so I removed the metal plate over the PCB and inspected, found what I thought was a loose wire & re-secured, put boiler back together. Tested, fault persisted, however I noticed that if I gently pushed the centre of the plastic control panel, the boiler would fire & stay on indefinitely whilst pressure was applied. Didn't have time to investigate further as it was getting late & dark. Just an update to put you guys in the picture, any further advice really appreciated.
Kindest regards Otto
This previous post may help if it's the relay issue
http://www.diynot.com/diy/threads/worcester-24i-rsf-l-combi-hot-water-problem-please-help.210558/
Yes, as above, it'll probably be the relay on the PCB. I had exactly the same symptoms and pushing the control panel in would make it work.
Thank you so much for all the advice guys, Relay ordered from CPC, will update once installed (y)
Relay was fitted, boiler has been fine since August 2016, have a problem with the shower now but that's a different thread, thanks for all your help guys, much appreciated.
Otto, in a soaking West Cumbria
