Worcester 24i junior lpg
1 Oct 2018
Have an intermittent fault in that boiler won't fire up for HW or CH. All pressures on gauges seem ok. Fitted in a caravan in Kent. Gas hob ok. And new bottle of gas.
Any ideas
Is it a straight 24i Junior (IE, quite old) or a Greenstar 24i Junior?
Commissioned 2012 can't see anything about greenstar on panel.
Bolier fired up just now. Had shower half way through boiler shut down. No fault light and will now not delight. It seems if we leave it a long while it will fire up again.
The originals with the grey fascia are notoriously bad pcbs, the early greenstar versions usually water pressure or pcbs but either way get it properly looked at as pcb faults on the 24i junior can cause massive additional problems
