Hello all,
I'm new here and have a number of questions regarding my bioler in my new home. would be grateful if anyone can help or advice where to go to get reliable help. Thanks in advance;
1- Kitchen radiator has a very small leak and usually goes if the rad valve is turned off. However, the pressure on the 28i boiler seems to drop below the default 1.5bar. Could this leak be causing havoc with the pressure? I will fix this very soon.
2- Sometimes, if heating etc has been running for a while, the pressure can get to 3 bar although never higher. The safety gauge shows the max pressure to be at 2.5bar. What kind of problems would over pressure cause?
Is there an easy way to reduce pressure if absolutely required?
3- The 28i Junior boiler makes the hot water at taps very hot after a short time. Is there a stat somewhere on the boiler to reduce temp?
4- Is it normal for water 'flow' at taps and the mixer shower to drop if another tap is opened? ie. if using the shower and someone runs a tap the flow drops and temp can change a lot.
Is there anyway to overcome this problem just for the shower (other than using electric shower)?
that's it for now. regards.
