worcester bosch 240
8 Oct 2005
Glasgow
Is there anyone out there who can help me.
I have had two plumbers in to look at my boiler but they can seem to find out what's wrong with it. Its a worcester bosch combi unit.
If i want hot water I have to turn off all my radiators, if the radiators are on i get about 2 inches of hot water then it runs cold.
Please help :cry:
Sounds like the diverter valve, with your heating turned off and cold run your hot tap and see if the pipes to the radiators start to warm up with the hot tap running for a few minutes.
Yes and if what Ollski says happens don't get either of those two guys back they should have found that.
Thanks everybody for getting back to me.
ollski if your there, I did what you said, "heating turned off and cold run your hot tap and see if the pipes to the radiators start to warm up with the hot tap running for a few minutes". nothing. The boiler didnt kick in to give me the hot water, I ran hot tap for 10mins still only cold water. Pipes remained cold. Does this sound like the diverter valve?
Sounds as if the diagphram in the diverter valve is not reaching the micro switch that tells the boiler you have turned the tap on, diagphram kit available and easy to change on the 240.
Sure ,got a couple in the van will get part number.
The diagphram kit Worcester part nuber is 87161405530 its about £12.00
