Hi, I hope that some kind soul out there might help me with a Problem with a Worcester 24cdi combi boiler. The system is controlled by a "Lifestyle 711" timeswitch (standard two timer on /offs per day program))and I have a single thermastat in the hall.
Problem is that when the thermostat is turned down so that it is "off" the Central heating part of the boiler keeps firing up for a few seconds and then switches off after a few seconds and then on and then off..... etc.
If the electronic timer is "off" then no problem or if the themostat is "on" it works fine and heats the water like normal. No problem with the hot water in the taps.
I thought it might be the timer unit so fitted a new one..... no change and still had same problem.
Havnt looked at the wall thermostat and have to say its pretty old but can hear click on and off as you rotate it. Also when the problem is happening it doesnt click on and off constantly so dont think it is that... that said could be wrong!!!
Any ideas would be really appreciated . Thanks in advance!!!
