Worcester Greenstar 15ri Pressure
Your boiler doesn't have a pilot light, the green light tells you it is lit.
Is the blue light flashing on the front of the boiler?
Perhaps try the manual overide on the zone valve in picture 8 whilst the timer/stat is in a call for heat mode.
Have someone watch the boiler whn you push the lever. it may fire, indicating that the sycronous motor in the valve is buggered.
Common fault in my zoned heating (Myson valves are pants for this) and an easy, cheap fix.
Worth a try?
Worth a try?
So the boiler sprang back into life last night after many more "ALT. CTRL. DELETE" and we've had heat and hot water all day.
Just home now and the boiler is off again, but schedule is asking for heat, we've tried to boost manually, but nothing.
In the airing cupboard there's lots of rumblings and all lights are on as expected (green light on heat and hw on the Hive box).
I've done as you suggested a few times with the zone valve, but no action from the boiler
Scrap that, the boiler just came back to life.
I have the zone valve in "Man Open" rather than "Auto"
Can I safely leave it there, or am I now a human thermostat control?
Aerjec may be blocked ,water starvation ?
Sorry, didn't spot this message.
We topped up the small tank in the loft last night, unsure if this is what got the boiler going again, but it'a gone again this evening (see comment just now). Unsure if this could still be the problem?
Your earlier posts indicated the boiler did try to fire up ,but not for long ??
Sorry, also missed this comment!
It was intermittent for a while, then totally dead yesterday.
We kept tinkering with bits and it fired up about 9pm yesterday and has been working well all day today.
Now, about 5pm, it was out again and I've got it going by adjusting the zone valve as above
The head tank has emptied?
Plumber time.
switching it to maual wont damage anything, but as soon as ther is a change in demand from you programmer/thermostats, if the motor is working , it will return to auto
Plumber time.
It wasn't empty, but it seemed to need some more water. It was tricky to see in the loft - it's not in an easy-reach place.
We have BG coming out on Thursday, fingers crossed they can sort it
Awesome, thank you. Will check it periodically to see what it's up to
