I have a customer with one of these beasts. The display is fluctuating between the flow temp and two little o's. From the Servce Book this indicates that the boiler is going through the Air Purge Mode which is supposed to happen only once when power is first applied to the unit and is supposed to run for around 8 minutes. Try as I may I cannot clear the display and get the boiler working. I have tried a restore to factory default settings; I have tried turning the Air Purge Mode off - nowt!
Any ideas folks? (Apart from the obvious
