I am hoping someone can help me.....
I have a heatslave 15/19 boiler and have had it serviced every year (for the last 6 years). The service is due in a couple of months, but we have have a problem.
I have bled the rads over the weekend and now the heating or water does not work. When I turn the boiler off and back on again, it kicks starts, but then cuts out after a couple of minutes.
The pressure is ready 1.0, as from what I have read, this is a little low, but wouldn't stop it from working.
I have taken the top cover off the boiler and bled all three allen key valves - There was alot of air in and I have since bled them on 2 other occasions, both of which air comes out.
The thermostat for the hot water clicks when you turn it from low to high, but there is no click on the CH (not sure if this is relevant).
I did call out an engineer yesterday who took one look at a blonde lady, scratched and said 'it all seems OK and should work if you leave it on all day, if not, I will come back and need to strip the lot which is going to cost you'.
Reading between the lines, it seems like everything seems to be working as it should, so should be a little problem.
I have also called worcester bosch and they told me to locate a silver flexible hose and bleed it - does anyone know where this is located?
Can anyone offer any help?
Please bear in mind, I am not technical minded and have no experince with boilers.......
Thanks in advance.
Thanks in advance.
