I have a worcester heatslave 15/19 oil boiler which has a rising pressure problem.The pressure gauge rises slowly when in use and then drops when not in use.I have disconnected the filling loop and checked the expansion tank which seems to be fine ie correct pressure and no water showing .The pressure also drops when the hot water tap is running which leads me to believe that the heat exchanger is the problem .I would appreciate it if anyone could adsvise me as to what the problem might be.Thanks in advance for any help offered.
