Hi guys
Would appreciate some advice ofF anyone that may know what is causing my highflow 400 to just work for water. The other night the heating went off so I checked the pressure and noticed it had gone right down so I filled it up but since then then central heating has not worked.
The hot water works & and boiler kicks in when I turn the water stat on the boiler to the on position and up, however when we switch the heating stat up and turn the programmer and room stats on, the pump starts and demand light comes on, but the boiler doesn't fire.
We have changed the diverter valve as we had a similar issue a few years ago and it was the diverter valve then but at that time the burner used to kick in and go off after a short time.
I've bypassed the programmer and heating stat with no joy & now have hit a brick wall. Would appreciate any advice given. Thanks in advance. [/quote]
