Yes, that's right. I also removed the timer receptor that is attached at the front of the boiler and after removing it the boiler still on. The hot water from tap is working fine as well. I also dismantled the timer and sounds like it's working.
Does your system include one or more motorised valves?
If so then it maybe a faulty motorhead incorrectly switching a live supply to the boiler/pump and hence your boiler is permanently on.
You need to check if this is happening with a multimeter or similar and if it is then replace the motorhead of the faulty valve. Normally no need to change the whole valve, just the motorhead.
More likely to be the MT10 mechanical timer. They break all the time. If removed the boiler will be on constantly. The timer must be stuck internally in the on position.
about the meter only saying that its ticking all the time and also when l try to change the temperature from the timer display ( which has day and night option) temperature doesn't change either.
