- Joined
- 27 Jan 2008
- Messages
- 29,557
- Reaction score
- 3,638
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The regulations do not in the text refer to new circuits but in the first few pages it states something like.It's a very strangely-worded reg (and does not "refer to new circuits"). The wording is is strange because it refers to "all circuits", rather than "each circuit". That means that, if one installs a new circuit and RCD protects it (leaving other circuits serving the room not RCD-protected), that would not satisfy the reg as worded.701.411.3.3 refers to new circuits so it depends if a FCU is fitted or not if a FCU is fitted then it forms a new circuit so would need to be a RCD FCU however if only the original fuse/MCB protects it then not a new circuit.
So circuits designed before that date are not covered which ever version is valid at time of design is what is important.BS 7671:2008 Requirements for Electrical Installations was issued on 1st January 2008 and is intended to come into effect on 1st July 2008. Installations designed after 30st June 2008 are to comply with BS 7671:2008.
701.415.2 Supplementary equipotential bonding is the odd one out where "(i) All final circuits of the location comply with the requirements for automatic disconnection according to Regulation 411.3.2".
So the way I read it any newly designed parts of the installation have to comply with current regulations but anything designed in the past only has to comply with regulations current at the time of design.
So if I want to add a socket in a house without an RCD I can use Ali-tube cable and a RCD socket or use a RCD FCU at origin and then standard twin and earth to standard socket.
The FCU is seen by BS7671 as forming a new circuit, but not it would seem by Part P which also means Part P needs it's own set of definitions as it clearly does not use those in the BS7671, however there are many other problems with Part P, not least in that it was not published in Welsh, so breaks the law. But as far as I am aware the question was not about the silly Part P regulations, but the IET/BSi regulations so what Part P considered as forming a new circuit has nothing to do with the thread.
