Hi all,
I am planning upgrades of two bathrooms and will be installing new down lights and extraction. I understand that these items will require RCD protection.
I have trolled a number of posts on here with a variety of advice. It would seem the easiest solution is to install an RCBO in place of the existing MCB on the Upstairs lights circuit at the CU.
Can anyone see a problem with this, or does each bathroom/installation need to protected individually?
Existing MCB is rated 5A with a max load of 800 watts... RCBO will be 6A with a max load of 1000 watts. will the existing cabling cope with the Amp upshift?
Thanks in advance for any advice.
