I have removed a stud wall between the living room and a bedroom to give a larger lounge.
I plan to patch up the gap between the two ceilings myself with smaller bits
of plasterboard. The two ceilings are at the same level (screwed onto
44mm battens which are in the underside of concrete bison beams).
I have been very careful to cut back the ceiling plasterboard to the nearest batten .
A couple of questions ....
Ian
1. Is there a chance this can be repaired without needing the whole ceiling skimmed? (I'll try and get some photos onto here later on).
2. If the whole ceiling does need skimmed, then can someone detail the preparation and process for this? (ceiling has one or two coats of white
emulsion directly onto 4 yr old plasterboard) e.g. what preparation is required, how long would skimming this take, how long before it could be painted.
3. Are the following correct:
a. 3mm gap should be left between cut edges
b. 12mm should be left between screw/nail and cut edge
Ian
