depends on how tidy you are if your like me
at the back of my bench is a band saw a belt sander
so there is no room for a door on it
as breezer say a workmate and matching sawhorse[home made]
for cutting doors
or the even easier way 2ft lenth 4 by 2inch wood
cut a channel 65mm wide 2 inches down from the top 11 inch
from each end cut at an angle one side of about 7% to fit
a wedge in so when the wedge is fitted the chanel will
have parralell sides
you lay the door lenthways into the block on the floor one end
tighten the wedge you know have a secure door with a piece
of wood at the other end of the door on the ground for protection
you can now cut hinge pockets mortices and plain half the door
easily hands free
