workin out kw's
18 Jan 2010
Blackpool
Say you had 2 lights both 500w, a heater say 2000w and a 13amp socket. The lights and heater come to 3kw's, what would you put for the 13amp socket
Its not for anything, its just what u was sayin about how many kw's a cable can take, now its easy to work out how many watts ur gonna use in ur lights, but how would u work out what ur gonna use in 13amp sockets
Just beacuse you're sending from a phone doesn't mean it should be in text style writing.
Please use real words.
You're going to have to be a little more specific as I thought I knew what you meant as per my post above but now I haven't got a clue :?:
uklad: people would have had a better chance of understanding your question if you had continued on the first thread. Making a new thread means no-one knows what you're on about.
The 13A socket can be used for any size of load up to 13A. You may choose to allow less if you *know* that it will never be used above a particular value of load, which is rather unlikely. But only you can tell that. So you would probably need to allow 13A for the socket.
For instance, there may be a radial circuit with a 20amp fuse at the consumer unit.
On this circuit there could be six double 13amp sockets. This a perfectly workable practical circuit in use in many houses.
6 x 2 x 13A = 156amps but the designer will know that most of the sockets will be used for TVs, Sky boxes, charging phones etc.
A different design would be used if the sockets were for electric fires.
A socket takes up to 13a but the load will depend on the appliance plugged in, which as a non fixed item usage will be variable. All you can really do is know that the whole socket circuit is limited by the fuse rating which is 30 amp for a 2.5mm ring and 20 amp for a 2.5mm radial.
On your example is the heater plugged in to the same ring as the socket ?
uklad - basically take note of this:
i have a 6mm swa running from my fuse box on a 50amp mcb with rcd about 60meters to the barn
That cable is far too small already, so you cannot use that for anything else.
As a minimum, you would want a new 25mm cable to replace the existing 6mm. The cable alone will be several hundred pounds.
and stop d*****g around trying to make what you want to do work without putting in a larger cable, OK?
Yes ban-all-sheds i did ask that about the barn and i thought that it was very interseting how its all worked out, its got nothing todo with that now, i was just trying to understand how it all works, sorry for askin lads seems like this site is just about doing it right not understanding why you do it right
Please repeat your question and we will endeavour to help out, I applaud anyone that not only wants an answer but has the curiosity to want to learn more.
From what I gather BAS has assumed that your question is based on attempting to try and find an alternative to a previous answer you didn't want / expect or like.
Unfair, given that you have stated that this is not the case.
