Worktop Lights
  • Thread starter Thread starter ryanj
  • Start date Start date
R
ryanj
Worktop Lights.
Should I power these from the lighting circuit or the kitchen ring main?
Also should these be switched independantly or on the same switch as the master kitchen light?
Thanks!
ryanj said:
Worktop Lights.
Lighting circuit is better, as then you don't have to mess about with FCUs
If you wire them as part of the lighting circuit, that would be entirely up to you. Most people would probably go for independent, but there's no technical reason - just decide if you want to switch them on independently or not.
If you power them from the ring then obviously they would have to be switched independently, and with a separate switch in a separate box - you could not use a 2-gang switch.
I've decided to use a 3-gang switch for the kitchen.
Gang 1 - Main Lights
Gang 2 - Worktop Lights
Gang 3 - Outside Light
Is there any problem with that?
Also, I planned to put the outside light on it's own circuit, would it be a problem to put it in the same box as the switches from the other circuit?
Or is there a regulation that doesn't want me doing that?
Thanks,
Ryan
all should be on same cct.
one cct goes, you need to check switch, very big surprise its still live from other cct
Maybe he's just realizing he's wired different ccts into the same switches in hundreds of houses in the area...
No, silly!
I'm the guy who comes along to a house that has two different ccts in an accessory box, and found out the hard way!!
Not that I would really because I never assume anything and always test......!!
Off topic, but a sparky visiting my industrial unit told me I had three lights served by a three gang switch, and each one was on a different phase. :shock:
Is it against regs to do that then or just bad practice? Is it something I should get changed by the original installers?
i don't think there are any regs specifically forbidding different cuircuits in the same box (correct me if im wrong here)
it is considered bad pratice with domestic lighting but is often unavoidable in commercial situations because each switch can be running at near the full cuircuit load
if theyare on different phases though the switch should have a danger 415V sticker on it
As far as I am aware, if it is possible to make contact with two live parts that are fed from different phases, then a warning label should be present.
