Hello,
I currently have my kitchen freezer connected under the worktop on an unswitched socket and above the worktop, I have a switched fused connection unit.
I now want to add in the same wall box a lighting switch and use modular switches with a double gang face plate.
I found modular switch for Freezer, and modular lighting switch, but I would loose the fuse. (The freezer plug is fused however)
Can I basically do this?
- have cables from main ring and lighting circuit in the same box?
- delete the fuse and just have the switch for the freezer.?
Thank you very much for your help.
