Worktop Mitre minimum distance from sink drainer
22 Dec 2011
What is the minimum distance from a Worktop Mitre to a sink drainer.
It is a 'n' shaped kitchen and the idea is on the plans to have worktop in one bit across the back and then mitre in the two side bits.
But I am not sure what the distance needs to be between the cut and the adjacent sink drainer......
View media item 42615
If you are using a mitred joint then it should not matter as if done correctly it will be a seamless finish with no chance of water penetration. The only obstacle may be the underlying cupboards regarding access to the fixings.
I thought it would have to be at least the width of the bolt, 150mm ? and was thinking would need more than this or could just snap the worktop when tightened ?
A pro will be doing it for me but is in Australia on holiday at the moment.
The worktop bolts are usually 150mm long which dictates if central you will have 75mm each side so a minimum of 100mm in that case. If it is not possible to move the sink to accomodate that then put the longest length of worktop in line with the sink and mitre the other length to it so the bolts are at 90 degrees to the sink.
