Worktop To Wall Sealant
23 Nov 2005
Nr Colchester, Essex
The grout along the top edge of my workstops, where they butt up to the wall, has started to break away. I also have a problem with the grout along the top of a couple of cupboards where they meet the coving also breaking away after cutting out a space for a new free standing cooker to replace the previous cooker which was built into the unit.
My wife is insisting I don't use grout again so wonder if anyone can offer a suggestion as to a good alternative that hopefully won't break up over time.
The only way to provide a flexible sealant, is to use silicone, Dow Corning 785 is very good.
Many people on here seem to believe that grouting to a worktop is the correct method, but it does not flex, and it is not as waterproof. And as you have found eventually it breaks away.
There are sealers other than silicone, and they don't migrate onto EVERYTHING in the way silicone does.
Thanks for the replies. I'll take a look around and see what I can find. I belive that Wickes do a Bathrrom, Shower & Kitchen sealant which might do the trick and has the advantage of needing a gun to apply.
I'll also keep an eye out for the Dow Corning as I know that's usually good stuff.
