Worktop upstand splash back thingy
19 Mar 2004
has anyone fitted these? They are like mini worktops but attach to make a small 90 deg. splashback. So the worktop has an angle at the back. When fitting is it just a case of gripfilling to wall and then silicon seal the corner? Advice appreciated. :oops:
Clear silicon, very easy to put up. The worst bit is cutting out for sockets etc.
Yes, just a decent size bead about 15mm inside the edges. After re- reading your post, I realised you are using the small one, so no sockets to cut around.
You could put a bead along the bottom or one on the front of the joint after it has dried to the wall.
