Would welcome help with boiler fault
6 Sep 2008
Leicester
HI,
I have a 30 yr-old Ideal E Type RS (35N ) Balanced-flue boiler.
The main burner is not lighting. There is power down to the gas-valve
( this goes to a solenoid, I believe, although it would be a 240V solenoid, whereas I have heard tell of 24V ones? )
The gas-valve 'knob' is grey. ( I dont know the exact gas-valve model, but it has V404 stamped on it ) I have performed the 'turn-on' procedure many times. In the past, it has always worked OK, but now it wont. BTW, the pilot-light IS lit.
I have checked the solenoid for continuity and the coil resistance is 5K. Rated as 240V@20mA, I would expect 12K. Also, I dont hear a 'clunk' from the solenoid when it energises, although maybe that's normal.
Is this a replacement job? Just how complex is it to fit a new valve?
I know you're expected to be competent, but it cant be that tricky to
undo 2 nuts. Does a new valve need 'setting up' or is it a plug-in replacement? ( just asking: it's a nightmare to try and find an honest trader )
Regards
Bruce
It does need a RGI to replace gas valve (if indeed that is the problem) and set it up, they are most certainly not plug and play!!!!!!!
Thanks for the replies
I probably need an RGI, but I'm dead reluctant to ask BG because their prices are OTT
I see you have a search engine for local traders! I'll try that
As for the solenoid resistance, unless I'm making a horrid algebraic error,
if V=240 and I=20mA, then R = 12K doesnt it?
bruce
Well it would if it was purely resistive.
But when you take physics GCSE you probably learn about inductive loads!
You badly need an RGI !
We dont give advice on or encourage illegal gas work!
Tony,
If the resistance R is 5k ( measured by the meter) and the required impedance is 12K, then if Z(coil) and R are 90deg out of phase, the coil impedance needs to be 11K and the inductance at 50Hz is 40H. I havent measured it, but it sounds a lot. I forgot that mains relays must have an AC component.
I still need a new gas valve!
Bruce
And after reading through, I have to say that in this thread, I totally agree with tony
Not probable you DEFINATELY need an RGI
BG prices may appear to you as being OTT but then you ( or your relatives ) may consider funeral director's prices to the OTT as well
But that was TWO years ago !
By now they will be even higher!
