WPB Water/weather proof ply
4 Aug 2006
Lancashire
Hi
Can anyone tell me if you need to protect WPB plywood from the elements or does it do exactly what it says on the tin..... Water/weather proof?
Cheers :rolleyes:
23 Feb 2005
Surrey
nowtaboutnowt said:
Hi
Cheers :rolleyes:
Depends what you're using it for. If you are building a structure with it then I would say definitely. For hoarding or shuttering then not worth it.
20 Aug 2004
Surrey
THE WBP only applies to the glue so yes the ply will ned protecting, prime, 2 undercoats and one gloss all oil based should do.
Jason
23 Feb 2005
Surrey
As mentioned previouly here, cuprinol shed&fence is decent stuff. a couple of coats will do it. Make sure there's adequate drainage underneath, sit it on pavers.
