Does anyone know where I can get a replacement for this pump, it needs to be the exact same pump as space is very limited, cant be any wider.
The only information I can see written on the pump is SB5, RPM 2850, W - 67 and Class F....
The pump is used to circulate my domestic hot water around the house, it was fine this morning but after turning off water supply to re route some pipework then after turning on water and running taps to remove air it isn't circulating water, running okay but doing nothing, gets very hot, have tried bleeding air from pump spindle but no change, looks like I need a new one...
Update:
I can find a Sb 5 pump on the Wilo website but it isn't a gold one and the connections are attached to the size and not on the top (12 Clock position) like the one I have..
Update:
