Yale alarm question
10 Jan 2014
Derbyshire
Hi , Ive just installed a new Yale wireless alarm which works great , but can’t seem to find out what the red buttons are for on the small wireless keypad?. They are called ‘panic alarm a & b’. I understand why there might be one , but two?
I wonder what model it is.
post some photos, too.
Sorry , here it is...
I don't know that model. Is the keypad described in
edit
can't see an instruction manual on their website.
I have an idea that on one of their models, you press both panic buttons together (to reduce the risk of it going off by mistake if you just press one)
Thanks for that, still can’t see where it tells you what they are used for?
Which page tells you this ?
Sorry , didn’t see all of your reply. That’s great. Thanks
Also, do you know if the PIR’s will be activated if they are pointed at letter box’s ?
it used to be better if they were aimed to capture someone after they had come through the door and were walking down the hall, so they were not activated at the same time as the door sensor, as the radio signals may interfere with each other. Your model may be different. They work better when somebody walks past or across the PIR sensor, rather than towards it.
I don't know about the letter box. Mine is beside the front door and points away from it.
If you press and hold both red buttons at the same time it will act as a panic alarm and set the siren off wether the system is set or not
