YaleHSA6400 Please Help
12 Dec 2011
Berkshire
Hi to all espiecially the Yale experts out there,
I have a fully working, all learnt in system, but if an alarm is triggered the outside bell/siren box is very very quiet. I have replaced all the batteries very recently.
Any ideas or prods in the right direction would be very much appreciated as i want to get it 100% as there have been a couple of nasty break ins down the road.
Luke
Was it quiet before you replaced the batteries?
I would imagine the new batteries are the problem.
Is the siren sounding continuously or is there a rythmic interuption?
its sounding the correct alarm tone but it sounds like its 5 streets away. unfortunately im unsure if it was doing this just before the battery change but i know when i first installed it the box was loud. its prob 3 years old now. i now think that even the arm/dis-arm beep is quieter therefore pointing towards it being an actual siren fault, as when i first installed it i turned the 'beep' off as i thought my neighbours might get the hump but it seems pretty tame now...
Yaleguy3 - have you had the actual sounders fail before?
Many thanks for your reply
check that all the batteries are correctly fitted. look for spiders nests or other wildlife in the siren.
Not had a sounder fail before.
Sometimes they can dislodge from the backplate and need snapping back into place but definately not had one fail.
I would check the sounder is properly clipped secure into it's backplate and possibly try another set of batteries.
I have replaced batteries in 3yr old sirens before and they always sound just as loud as they should do.???
John D may have a point - there could be some debris in the sounder if something has been nesting or laying eggs.. if something is covering up the holes in the backplate then sound won't get out. You might want to remove the siren from the wall and check the sound holes are clear.
Ok cheers guys I'll check the sounder then try with the batteries.
Thanks for your replies
