Hi, I recently bought a two-bedroom house which has a Baxi Solo 2 50PF boiler in the garage, Drayton Lifestyle LP522 controller in downstairs wc, a large hot water tank in the loft, 4 radiators (one without temperature control in the downstairs hall - presuming this is the main one? the rest with controls), and a heated towel rail in the bathroom upstairs, which has a temperature control.
Being a first-time buyer I was advised by my solicitor to get the central heating system checked no later than 5 days before date of entry, for which I enlisted the services of a local gas and heating engineer. He checked the system and declared it in perfect working order, of approximately 8-10 years old, and a british gas installation of good quality.
Upon entry date I moved in and the previous occupiers mentioned as they left "sometimes the boiler needs reset, just turn this knob round to 0 and back round, we've had it checked by various folk and they can't find anything wrong with it, but it only does it sometimes"
I think their definition of sometimes differs from most peoples... every day without fail at least once it will lockout with the overheat light lit and require reset. I got the guy who checked it back to have a look, he denied that he missed anything in his check of the system and was assured by the previous occupant that the the system worked perfectly - seeing as the missives stated that they were not responsible for any repairs costing less than £250 I was not unduly worried because he had stated it was in good order, figuring that it would work as expected.
In attempting to rectify this fault he has replaced part after part, without testing pieces before replacement.
So far I've had the following replaced at my expense...
It only seems to go to overheat when the central heating system is on, hot water only does not seem to trigger it. I tried turning off all the radiators and towel rail apart from the main hall one which doesnt have a temperature control knob - it lasted for 2 days before kicking to overheat, which is an improvement, but a chilly experiment.
The boiler doesn't seem to make any strange noises like banging or clunking (apart from the light ticking noise when cooling down - I put this down to thermal expansion), but it does click on and off when operating - fires up for a few minutes, then off again for a couple of minutes, then on again - don't know if this is by design. All radiators get nice and hot, and the water gets hot too. I have the room stat set at 20c, the danfoss stat below the boiler set at 55c and the hot water tank in the loft set at 55c. The valves move as expected, the pipes and pump get hot.
Any suggestions as to what to try next? I had suggested following the forums on here to him that it may be the PCB board, but he won't fit one for testing and remove if it doesn't make any difference, and I don't want to buy one unless it's almost guaranteed to be that.
I sought a second opinion, engineer #2 who is difficult to get hold of and seems to be less than reliable at turning up when he says he will says that from my description (he hasn't seen the boiler yet) that half those parts shouldn't have been replaced, it won't be the pcb, but probably a blockage somewhere - is there anything I can do myself to check for that?
I have the installation and servicing manual for the baxi if it helps with part numbers etc, but as you can probably tell I am a complete novice with central heating systems so please be gentle with me!
Pump
Overheat Thermostat
Thermostat Sensor
Automatic air vents fitted to tank in place of manual ones, and an automatic vent fitted to the boiler "as there wasn't any before and there should have been"
Boiler temperature control potentiometer
