Well, they're related and, generally, proportional. What else do you need to know?Denzil said:Ah, the mysteries of the pressure flow
I'm assuming that this means that you've measured your static mains pressure and that this is the measured range.I'm having something called the Dual Thermostore from Chelmer Heating which says it delivers hot water at mains pressure which is between 2 and 2.8bar depending on time of day.
Well, not really - low pressure outlets are intended for gravity (aka tank-fed) services, where the static pressure is usually between 0.1 and 0.5 bar. If your hot water is being supplied at around 2.0 bar then it opens up your range of options to include taps/valves suitable for use with high-pressure.Am I right in thinking that I need "low pressure" taps and bath filler
You won't be able to use a pump if the services are all mains supplied. It's both impractical and against the law (Water Regulations)....but at the same time could probably get away without needing a pump...
If it's intended operating range is 1.5 to 3.0 bars, then in your installation it will be just fine without any pump....for the shower which the manufacturer says can work ok at 1.5 bar but the supplier for some reason tells me needs a 3 bar pump. (Hansgrohe Raindance Showerpipe)?
