zanussi hob one ring dud
26 Jun 2005
Tyne and Wear
one ring has stopped working on electric hob. other 3 ok.
what is it likely to be & will i be able to diy.ceramic hob
Sure to be the ring element below the ceramic....I get a lot of these bits, and advice, from Forresters of Bedlington 01670 823033. Canny lads and lasses if its not too far away.
John :)
If you can disconnect the electric supply, release the hob from the worktop and turn it over, its usually only a few screws or similar to remove. These things aren't usually assembled very well!
John :)
