Zone valve sticking
chp
23 Mar 2007
Moray
I have a heating system zoned by Drayton zone valve actuators. One of them sticks open sometimes - not every time.
If I tap it with my finger it works - just like magic.
Everything else works okay.
Could the cause be the valve or the electrics behind it please.
it is mechanical with a micro switch .. they are not very good to be honest .. but easy to swop .. as you dont need to drain down ..
personnaly i would replace the top only .. although the bodies do sometimes fill with crud and sieze up wich in turn burns out the motor..
a proper job would be to swop for a honeywell lots better .
http://cgi.ebay.co.uk/22mm-Honeywel...oryZ3191QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
It is marked as a ZA5. The system was installed new 4 years ago.
Is that an 'old' type?
Should be ok. Available from any major plumbers merchants or parts suppliers.
