ZWF1640W washing machine not working
Yep, on all programs, even just drain!
At the moment I go into diagnostic mode (hold start/ turn to first option) and then "test" the water filling to get the water in the drum. Then exit and start the actual the wash - previously this didnt work, but has this morning!
So this morning I ran a white wash at 90 degrees, that worked fine - empty drum
Immediately after that I ran the spin cycle - empty drum.
Both worked fine.
Then I put a load of washing in, and ran the coloured at 40 degrees. Started draining, and then stopped, timer on 0 and door unlocked.
Put it back on spin with a load, same as the coloured wash.
Filled with water so the bottom of the drum had visible water, then started the coloured wash, still no joy.
As you will have realised by now you have a weird problem. I think your machine has a brushless motor but am not 100% sure & worn motor brushes can cause weird problems so it might be worth checking that. Other than that you mentioned removing the pcb & warm weather, did you remove & replace plugs & sockets as I am wondering if you have a bad connection from the pressure switches at the board. Other than that I can only guess it might be a fault in the wiring to the press switches or as I said earlier a faulty pcb. (not necessarily something you will be able to see by visual inspection).
The plugs were removed/reseated when i changed the pressure switches a month or so ago, and then reseated one of them lasts night, and re checked the other at the same time.
The connectors to the pcb were removed and refitted also as i removed the PCB.
I guess one more opening and checking the wiring loom, connections and brushes. There is a service i found on ebay who test and repair the pcb's for approx £40 so may have to look at that option!
The heating element is working as the 90 degree wash resulted in a warm bowl, but will double check those connections too!
Again this is a very belated reply, but might still help someone. See long description on thread about a ZWF1640W Zanussi washing machine, which looks like the one picture you post internally and how you describe it. This had exactly the fault you describe, with an intermittent refusal to start for many years, plus I also noticed a tendency not to run two washes one immediately after the other, but worked better if i waited a bit.
You first say the error was E34, then later E35. Assuming it was E34 this means inconsistency between the analog and mechanical pressure sensor. In your pic there are two tubes coming off the drum from the bell pressure chamber, one goes to each.
The step which fixed my machine was to enter the service menu, exit the menu by moving to the power off position, then switch on again to any setting. This starts a different process which I have not seen described in any of the service manuals i have found online. The display showed ELE I think. The service descriptions didn't explain this, merely said that once you reach this step immediately switch it off again and then it would work normally next time turned on. However, I let this run, it filled the drum to normal wash level, maybe did a little splash, pumped out and then stopped. After that i switched it off, then back to a wash cycle and it worked normally.
I suspect this runs a calibration cycle between the analog and mechanical pressure sensors. I suspect that because some info about other brands of washing machines talks about calibrating the analog sensor, and it makes sense how the hardware could be OK but the machine not be working, or having an intermittent problem.
Before I got to this stage i had already replaced the analog sensor and checked the mechanical one which seemed to work fine. By itself this didn't fix the problem, until I did the cycle as above. Since i had a new sensor anyway I didnt switch back to the old one, but its possible the old one was working fine but somehow its calibration has drifted over time so that it was first sometime out of range and then permanently out of range. So its possible just doing the calibration run would have fixed it without even having to open the machine. Or it could have genuinely failed.
While investigating all this I found the circuit board was completely covered in black dust, which I think was ground up carbon brush dust from the motor. I cleaned this off because it didn't seem likely it was helping, but by itself this didn't fix anything.
Oh, there are a whole lot of different models and different name machines which are very similar internally to this one. Hotpoint EWM2000evo motherboard. Note though different models may use different software programming on the same board.
