How to skim a long wall and ceiling?
19 Oct 2005
London
Hello
I want to skim a large room.
I presume that experienced plasterers' would be able to skim each wall in one go, but would I be able to divide a long wall into sections to make the job easier?
Would I use straight beading to divide the wall?
Two of my walls are 20ft long, what distance would I space the beading?
Am I also able to you the beading on the ceiling?
Any advice would be greatly appreciated.
Many thanks
olneys
You can buy stop beads from B&Q etc but it will not look good. Practice on small walls you will be surprised at what you can achieve. On the large wall you can throw the 2 coats on it does not have to be pritty. Its the third trowel that is vital that you hit it at the right time which is when you put your fingers to the wet plaster and it barely leaves an inprint.
agree with brist, forget the beads, it will look a right pigs ear!
on very large ceilings, we have in the past, had to have a join. it is best to stagger the coats so that the join is stepped. this makes it easier to grind in the join later on, when you apply skim to the other half of the ceiling.
I hope you've got some plastering experience or you'll make a right pigs ear of it.
Everyone thinks they can plaster, but without experience, they can't. Best advice he's been given yet.
A couple of years ago I had the task of plastering the back wall of our new conservatory; 5m wide & 3.5 m high at the apex (total around 16 sq/m) but I had only worked on smaller walls, mostly less than 10 sq/m & without the access problems! I was much slower then & far less confident I could hit it in one go so I plastered the wall in 3 sections using a full height stop bead (reversed) to plaster up to. After finishing the fist section, I repositioned the bead, re-mixed & carried on with the next section, completing the whole wall in about 3 hours.
It turned out really well, you can’t see the join & it hasn’t cracked open after 2 years. Nowadays I could do it in one hit (just done a stair well which was even more challenging) but if you’re a beginner working on your own, using a stop bead can work out well as long as you complete the whole wall in one hit.
On this occasion though, I would agree with joe; plastering is unlike anything you will ever have tried before & you really need some experience before tackling a wall that size, it’s not one to cut your teeth on!
excuse me thats not spam, thats information relating to this topic, if it was spam then I would be blasting the forum with url's
This is a 24 page Ebook teaching you the basics on plastering, I thought it would be useful on this forum
