Cast Iron soil pipe - WC Waste Connector - (pic)
23 Jul 2007
Hi
At the weekend i'm suppose to be fitting a wall hung toilet to replace the old one. I think i may have a huge problem with the existing soil pipe in the bathroom.
Once i fit the wall hung and cistern the existing soil pipe projects really far out and i don't think i will be able to buy any type of connector to join it smoothly as it is
this is the exisiting cast iron pipe - what is that huge bulge ? it narrows again after that. it's all cast iron outside as well.
at the moment that is connected to the new toilet , but it's only sitting on the floor at the moment , as i accidentally put a hammer through the old one a bit ahead of time :)
it will be raised up quite a bit , once the wall hung pan is in it's correct location i think i'll have probs with the waste connector , beacuse it will be almost directly above that pipe and a bit less distance out ...hope this makes sense.
can it be cut ? it's close to the wall but i might get a grinder in there ?
any suggestions or possible fittings i could buy ?
You're on the right lines.
What's the vertical offset?
The bulge is a "socket" full of very hard cement. If you drill it with a diy-type hammer drill you'll be able to break the cement out in lumps.
If all else fails you replace a section or all the outside pipe with plastic, which isn't as hard as it sounds.
Thanks ChrisR ,
Is that socket joining the 2 pipe sections then ? and if i remove it will it give me some more room ?
Replacing the whole stack might not be so easy on my house. That soil pipe dissappears into a roof area on 1930's small kitchen extension , the kitchen below sticks out about 4 ft from the rest of the house , it exits from the side of the roof and i'd have to strip off the roofing to get to some of it.
have i got any hope of removing that join without breaking the rest ?, that would be a disaster for me :)
i've already smashed the bog 4 days early and the wife was horrified !! :)
Check the offset and the angle of the cast iron soil pipe in relation to the new pan. It looks like the existing pipe may have quite a lot of fall on it.
Multikwik (among others) make a range of pan connectors and extensions to cater for offsets of up to 100mm
http://www.multikwik.com/wcconnectors.php
if you can clean the cement out the existing socket, you may find a pan connector will fit inside the socket with a bit of room to spare.
The tricky part, whether you remove the socket or not will probably be cleaning up the bore of the cast iron enough for a pan connector to seal and to avoid tearing the fins when you fit it.
Depending on the toolkit and elbow room you have available, cutting the socket off with a hacksaw (18TPI blade plus a large tub of elbow grease :) ) is possible.
Others may recommend saving on the elbow grease by using an angle grinder.
Great stuff , thanks
I might take the elbow grease route , i've got 2 grinders 4" and 9" but it's close to the wall , so might not get in nicley
I'll go and measure the offset and post later..
cheers !
Easy to cut off with a small angle grinder, though you fill the area with iron dust.
What you have is
and you can cut it off anywhere from the dotted line backwards.
Thats excellent chris , now i can see what it's all about.
I think i'll cut that off as it will give me more options for fittings , i'm wondering if a flexi will do the job ?
You can do the blue cuts with a reciprocating, jig, or hack saw, the green ones with the angle grinder. Small bridges of cast iron snap easily.
Cheers Chris , just popped out and bought a reciprocating saw ready for the job on saturday , a useful tool anyway so it's all good.
I'm sure there will be tons of curseing , swearing and foot stomping :) , but i'll get the job done !
I'll post back and let you all know
Thanks for all the help ..invaluable to me
TicklyT said:
If it does, you've cut into an air conditioning duct by mistake :P
LOL :) let me re-phrase that .....
"I'll find out if the s**t hits the reciprocating blade on saturday" ;)
SUCCESS !! :lol: :lol:
4" Grinder did the job nicely in the end (had to take the guard off)
Cheers guys
