Recently had consumer unit replaced with MK sentry job, split load.
Downstairs light circuit suddendly stopped working BUT the breaker hadn't tripped. Initially thought the breaker might have died but is working OK.
So inspected the connections in the consumer unit, no probs, and the various ceiling roses/junction boxes. One showed evidence of heat - clear plastic covers on the connection terminals discolored over the -ve's, and a general "soot" on the wires.
Removed, cleaned, inspected and reassembled. No apparent defects in the insulation on the cables, although there was a fair amount of unsheilded earth which I rectified. It was all a tight fit coming apart but went back much more neatly.
After reassembly the circuit now works fine. However, there is a slight buzzing coming from the consumer unit when lights are on, which increases with load, although the breaker doesn't trip. There are some LV downlightss with electronic dimmers and transformers on the circuit.
Any ideas on the buzzing?
Cheers
Jim.
Cheers
Jim.
