Removal of Heritage Tap Indicies?
27 Feb 2006
Hi all
Long time no visit but here's an easy one for those of you experienced.
My 4 year old Heritage 'Hot' taps ( http://www.heritagebathrooms.com/pages/pd_tandm_loxleigh.html #) have all begun to be difficult to fully open - I'm guessing limescale build up in the valves.
So, easy, just replace the valves or descale... uhm well that's what I thought until I started to break the fragile indicies.
My first attempt was to 'pop' them off with a flat blade...nope I should have looked here: http://www.heritagebathrooms.com/images/spare_parts_images/sp_pop01.jpg as it appears they maybe threaded?
So can someone confirm indicies removal technique? I've also tried unscrewing but they're so fragile they're cracking and simply not budging!
Would be much appreciated, thanks
Lea
If they're cracking then there's no need to be careful with them - fit new ones when you've finished the job.
They're definitely threaded, so to remove them just grip securely with grips, or pump pliers (but not with so much force that you distort the brass part of the index), and turn anti-clockwise.
If the ceramic/plastic parts breaks up, so be it. You can grip the brass portion.
Hi softus
Thanks for the thread confirmation, yes that's the conclusion I came to also. Best I begin ordering spares :)
Many thanks
Lea
FYI
Dear Lea
Thank you for taking the time to contact us.
Depending on the age of the tap we have 2 sets of Loxleigh indices, the first set are the same as the indices in the picture you provided. They should just unscrew off, the second set are the older model which have small teeth on the under side of the indcie. The just pull out. But they will only apply to taps that are at least 4 years old and over.
Hope that helps
Regards
Heritage Technical
