Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Is it OK for gas pipes to be routed through a roof space (cold zone)? Not intending to mess around with my gas pipes - just a project planning question.
It's not the loft, it's the roof space in the eaves of the garage. As for communal use, there is no access to the area whatsoever. I've had to cut an access hole in the ceiling just to get up there and once the installation is complete the access panel will be screwed back into place.
I'll put some marker tape on it anyways if it will keep the goverment's sticky-tape regulatory body happy
