Hi, I have a new shower but the hot water is intermittent.
It is a fixed shower head with a valve shower and I have a 2 bar shower pump. The pump is on the floor next to the hot water tank, which is below the cold water tank in the loft. The cold water tank, hot water tank and pump are all about 15-20m from the shower.
When I turn on the shower, in order to get the pump to start, I need to put it fully on cold water only. As I turn it to hot, the pump stops.
If I move it gradullay to hot, then as the hot starts to come through, the pump stays on, but often it will cut out again and I have to go back to just cold.
Help - I need a hot shower!!
Could this be the shower head? Or is it more serious (it's only been stalled for 5 months and only just started doing this)
Many thanks
Many thanks
