Cost estimate of double glazed panes
12 Jun 2009
I'm looking to refurb some sash windows and replace the agine glass with double glazing panes. What sort of ball park price can I expect to pay for a double glazed pane of approx 16" x 20" if I'm ordering at least 4
if its normal single glazed windows its not that simple and reworking windows /d/glazed units for small rebates are expensive
Big-all is right. You'll probablyly need completely new sashes to get a rebate big enough for a D/G unit and even then I doubt that you'll get more than a 8mm gap (16mm total thickness of unit).
You should certainly shop around for prices, though. When I needed some units a couple of years ago a supplier in middle-class Surbiton wanted three and a half times as much as the glass factory I eventually found on an industrial estate in Hackbridge. Suppliers usually base their prices on area + an element of fixed costs. The good ones can give you a quote over the phone.
about £10-£15 a unit for float (non-safety) glass units. you could look at using stepped units, but it's not a great solution.
