Hi
New here and have read through quite a few posts and it has been really informative as we are planning a two storey extension.
The first question(of many im sure) is that we are having an extension built shortly 3.5m x 7.1m (two storey), with the front of it being brick, cavity and then block construction and the side and back of the extension will be finished in render (to match the exisitng house).
A builder that we do like suggested that he would build the side and back of a single block 215 x 215 x 440 and have a 100mm Kingspan insulation and then batton and plaster board as opposed to Block, cavity and then block again.
My main question is is this ok and would there be a massive heat loss between the two?
