I am in the process of changing the bathroom radaitor (10mm pipe) to a towel rail (15mm pipe),
with the CH system turned off is it possible to swap the current radiator valves for 10/15mm reducers (already connected to the towel radiator) without draining the system or freezing the pipes?
This is on a non pressurised boiler, so would it be possible to do this "live" without too much water loss, the floorboards are up at the moment so i can place a large bowl under the joints whilst changing them over,
or would this just be a bad idea?
