Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
dependent on the size and what its holding back, yes you can, but youd do it as a single brick wall rather than in skins. depenedent on the height etc, the lower part would be 3 bricks wide, the middle two bricks wide and the top 1 brick wide, if that makes sense
It would be ideal if they were engineering grade bricks. Unfortunately your bricks will probably break down in time. (but probably not in our lifetime).
