Possible to build retaining wall without ugly engineering bricks?
r_c
19 Jun 2016
I am a lay person, so please excuse my ignorance here ...
Our drive is about 30-50cm above the pavement level. The current retaining wall (about 1m tall) is single skin (some kind of faux grey stone) and seems to have been patched up a few times. We've been told it should be replaced with a brick wall that is two bricks thick - or something along those lines as single skin isn't so strong. And we've been told that we'll have to use engineering bricks.
But they don't look very appealing (sorry if this sounds vain). Is there any way to build a retaining wall with a nicer facing brick?
Thank you.
Engineering brick just means it has been fired at a higher temperature than standard bricks, it makes them more resistant to the frost.
There are various grades and styles even within "engineering bricks", you also do not have to use the same brick on both sides.
So look around at the choices available, their might be one you really do like.
  • Thanks
Reactions: r_c
You should not judge poor old engineering bricks.
:mad:.
But you have been told incorrectly.
  • Thanks
Reactions: r_c
Thank you.
As long as the brick is rated then its ok. All bricks are sold with a durability rating, you just need to find one suitable...
Noseall, please put your lid on the correct way. The label should be at the back out of view. :D
Nice retaining walls! Do you know where the bricks were purchased from and what they are called?
Can you please tell me what rating should I be looking for?
This one says "F2 rated for frost resistance". Is that what is needed?
Yes 'F2' is good. But with porous bricks you also need to look at salts content. 'S2' would be good.
  • Thanks
Reactions: r_c
The ones in the image are called 'Oast russet' and are F2/S2 rated. They are irregular shaped hence my choice is to flush the joints ad rub. Striking or bar jointing tends to look wavy with irregular shaped bricks.
  • Thanks
Reactions: r_c
Thanks @noseall . Those bricks (I like them!) have a water absorption of <= 21%. But Internet tells me an engineering brick should have < 7%.
So what is stopping the water seeping through your retaining wall?
PavingExpert has a diagram of a retaining wall with a DPM. Is that the bit that I am missing here? And I guess engineering bricks are not need with DPM and hence why you say look for F2/S2?
The bricks are backed up with 7n dense concrete blocks and only showing Oast Russests on the uppermost courses i.e. where visible etc. There is also 1200G polythene up the back of the wall. You may be able to spot the edges of it poking above the soil...
  • Thanks
Reactions: r_c
