Washing machine drum not turning
20 Sep 2006
Hi i have a indesit w93 washing machie and the drum does not turn properly.Its very hard to turn and real noisy.When the machine is on the drum just jams and then stops.Ive checked the belt and motor and both are fine.I think the bearings are shot am i correct?Also bits of worn plastic have come out of the machine i suppose from wear of drum housing?How do i get to the bearings to check them?Is this job easy enough to do myself as i cant afford to call a engineer?
Many thanks big ash
The bits of plastic are shreds from your outer tub where the inner drum has been rubbing on it.
To be honest, it's a nightmare job and probably not cost effective either.
With the damage to the outer tub you may have to replace not only the bearings but the tub too.
Anyways, everything has to be disconnected, make diagrams, and the whole tub comes out through the top. Bearing kit and tub seal required as a minimum. Probably need a heater too, if the drum has gouged it.
These cheap machines look a great deal at the start but you'd be better off saving a bit more money up and getting a decent machine.
