I'm tiling my kitchen with 300mm x 100mm ceramic tiles. I am tiling above the worktop, I think the usual way to do this would be to place a batton above the worktop, tile up from here, then fill in the space between the batton and the worktop.
I have some wall cupbards above the worktop and I've measured the distance between the bottom of these and the worktop. It's approx 650mm, so working on this, I will get six tiles in then approx half a tile remaining. What I want to know is wether I should put a whole tile on top of the worktop and tile up to the bottom of the cupboard, as above the worktop is more visible than under the cupboard, or do it the other way round, leaving the half tile at the bottom. Or, a quarter sliver at top and bottom.
If I do put a whole tile at the bottom, shall I measure up from worktop a whole tile lay the tiles on a batton level, then fill in below in case the worktop isn't 100% level (although I think it pretty much is)
thanks
chris
thanks
chris
