Regulations
If a conductor is continuous and connected to both switches it doesn't matter where (along that conductor) you connect the live or load.
Not a very good drawing but this is what am planning :)
Fair enough mate you can put power in the slave and take it to master but that would mea the load would have to come back upto the light from the master so I would have to run a double up for that anyhow so may aswell send down a 3 core from the slave to master and a 2 core for the split live :/ confusing myself now lol
Yes you can connect the live at any point to the L on a master or a slave but (and this has been said a few times before) it must be an L from the same circuit as the N.
Usually, when runing this sort of set up, you can use the existing 2 way (or more) cabling, but you need to be sure of the routes and that there are no surprises. For most 'smart' dimmers a 3-core and earth is needed between all points.
Some other dimmers (Retrotouch e.g.) work with only 2 wires between the master and slaves, but they have other horrible challenges, that I wont discuss here!
Yep the ceiling roses ain't been updated so they all go to a junction box in the attic it looks like a birds nest!! I do want to replace it with something bigger to space the wires out more is there anything that's made for the job to do this??????
Where the live is split in the junction box for the switch ? :/ I think lol
Does anyone have a better idea than this circuit/situation ? Any input would be appreciated ?
I think you are still missing the point.
On your latest drawing, transpose 'M downstairs' and 'S landing' and it will be easier to wire.
How big is "bigger". Something like this? http://www.tlc-direct.co.uk/Products/ASJ701.html
Let me re-word that mate I mean instead of having the junction box I have which looks a mess and all the earths twisted together to hold the top on the box it's self is there a type of junction box made for what it's doing that gives more room to put all the cables in neater and safer and a terminal for all the earths also Mabe a few more extra run off points for my bathroom fan and mabe any extra lighting :/ ?
Yes, I know, so connect the L and SL to the slave at the landing.
The master and salve are connected with a 3 core like the Varilight circuit drawing says live, load and link all connected one 3 core cable ? :/
